I did some research on this. It appears the blinking red light is to indicate there might be a problem. The "blinking" is actually an error code. A certain number of "blinks" is indicative of certain types of errors. This is similar to a cars "check engine light". A car is scanned to get the code, which can help lead to the problem. I found a common source for dryer codes according to the blinking red light here: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134859700e.pdf
I hope this helps :-)
It is probably the projector bulb. The two red blinking lights indicate bulb failure. Replace the bulb and also thoroughly clean the cooling fan and vents to prevent future overheating which can shorten bulb life. Hope this helps. Bob
The bulb that illuminates your screen needs replaceing. This blinking light is an error code that tells you when your bulb blows. Please have tech replace it or do it yourself its easy.
Hi, 4 times red standby light indicates problem with exhaust fan that is not running for some reason. Recheck fan that you replaced and make sure its connector is plugged properly and it running freely. 4 times red light blinking is fan error in this tv. Thanks.
