Dabbing is onlt possible from dvd to vhs but not vhs to dvd
SOURCE: How do I change the region code?
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__de4567y
SOURCE: Sony VX420 combo what region should I set it
Region probably has very little to do with it. More likely than not it is either the content you are recording to the DVD is not in a format compatible with a regular DVD player, or you are not properly finalizing the DVDs you record on the device. Normal DVD players require the final block recorded to be finalized in order to be able to recognize and play the content. The recorder does not have this requirements as it leaves the block open in case you want to add more content.
