HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
SOURCE: my imei no. is 354862026555404
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
SOURCE: hello
you download the software "UNLOCKME.sisx" and install in to your N95 and run that it find auto...if not possible to open your mobile then...first switch off your mobile press green button,*,3......three at a time and then switch on your mobile but dont up your finger on that three switch until show country selection..if unpress your finger then that is not complete...have fun....."PREMASHIS PODDAR [siliguri,india]"[email protected]
SOURCE: I forget my security code
if you forget your security code you need to reset your phone. you can either reset your phone through codes or through software. for new model phones its better to go with sofwares. i got my phone reset through codes and i got the codes from here for free of cost. since my phone is a basic model one i got codes from here. if you have any basic model phone which you cannot reset it you can try here.
Unlock-Free
SOURCE: Need unlocking code of Nokia 1280 (RM-647)
try this. switch it off. now press * 1 3 all at a time and switch on. might help.
