Drills Logo
A
Anonymous Posted on Sep 09, 2016
I would like a new charger Ryobi bc-1807t charger and 2 batteries. or a repair to my charger
I have lots of drills and power tools for the batteries that are used in the Ryobi bc-1807t charger. so I need a new or second hand replacements or my own repaired
john h
Level 3:
Top Expert:
  • Ryobi Master 29,494 Answers
  • Posted on Sep 09, 2016
john h
Ryobi Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7546795
Points
193449
Home depot -lowes -most hardware stores--go online to buy the replacement for repair do a search for tool repair store in your area but might be cheaper to do replacement
P107 red light on green light flashing 2 batteries neither will charge ryobi 18 volt lithium charger working could both batteries go bad at same time
Replacement for Ryobi P107 Power Tool Battery
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
  • Dimension: 135.70 x 76.00 x 107.30mm
http://www.drill-battery.net.au/buybatteries.php/ryobi_P107_power+tool+battery.html
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
Can I buy a battery charger for a ozito drill
hi Terry.
you could try homebase.or ebay will have them.
or this link should show you where you can buy them.
battery charger for ozito drill Google Search
Dec 02, 2017 • Drills
Is there 2 type of battery chargers for ryobi one+ and lithium 18v one +
I just went through this with Porter Cable 18V but I can't say it is the same for Ryobi. On the PC, all 18V batteries are interchangable on the tools, but the charging needs are different. A dedicated NiCad charger can't shouldn't be used for liOn but the later chargers will work for either battery.
Ryobi offers an 18V upgrade:
RYOBI Tools
What is the best way to store the new ryobi 18v battery
Is your ryobi 18V battery is a Li-ion battery? if so you can store it with 40% power and keep it clean, cool, and dry. Then every 1-2 month to charge and discharge the battery for once time.
More battery tips or batteries and chargers for cordless tool you can come here:
Cordless Drill Batteries Replacement Cordless Power Tool Batteries...
Nov 02, 2014 • Drills
I have a Ryobi set ( elec saw, jack saw, tourch and drill,but my battery charger has gone kaput! I will like to buy a new battery charger BC-144T so I can use my Ryobi set. Where I can buy a new battery...
I checked a couple sites and would suggest calling RYOBI parts supplier at 1-877-545-4099 to ensure that you get the correct charger. They might ask you what the model nnumber and the voltage and type of battery so have these numbers handy. Let me know if you need more assistance.
1helpful
2answers
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
2helpful
Lithium batteries?
Just got a reply from Ryobi tech service and it says that "all Ryobi 18V platform power tools can accept and use the lithium batterys, but you must use the charger for the lithium to recharge them. Hope this helps. Dave
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
