Simmons SD9K Electronic Drum Set Logo
G
Gary Nice Posted on Sep 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have Simmons SD9K drum kit. Started having a hum. Tried thru head phone or Mackie board. It still hums. Pulled each cable to drums or cymbals and it still hums. Anyone know what is causing this.
It started having a hum. I tried it in the head phone or thru my Mackie board and it still hums. I pull our each cable to separate drums or cymbals and it still hums. ???
Vernon Taylor
Level 3:
  • Simmons Master 7,446 Answers
  • Posted on Sep 10, 2016
 Vernon Taylor
Simmons Master
Level 3:
Answers
7446
Questions
0
Helped
1959726
Points
26207
The hum is likely to be the sound of the ac mains electricity, either because the power supply smoothing has become ineffective in the amplifier or one or more of the audio peripherals or because the audio connections to the input of the amplifier have created a hum loop that is picking up the radiated energy from the mains supply and feeding it into the audio input.
Multiple grounding is often the reason for a hum loop. This is where an audio peripheral is not only grounded through the supply cable but is also grounded through the screened audio lead.
If the hum persists when there is no inputs connected the problem is almost certainly power supply related, otherwise it is likely to be a peripheral that has a faulty power supply or the culprit is a hum loop.
Hi-fi officianados have a number of tricks to deal with hum loops and google could lead you to these.
Grounding is an important safety consideration so appliances that are intended to be grounded must continue to be grounded but the loop could be broken by using special audio leads. The usual lead would use the screening as a conductor and so the screen must be connected both to the peripheral and to the amplifier.
A better lead uses an extra core conductor and the screen then becomes just a screen and is grounded only at the amplifier end and is not connected to the peripheral.
I hope this helps.
Does anyone know if I need the 'Brains' of the ION IED01 electronic drum kit, or can I plug the USB directly into my laptop? Somehow, I've lost that module and only have the kit!
The ION IED01 electronic drum kit requires the "brains" module to function properly. The module is responsible for converting the signals from the drum pads and cymbals into MIDI data that can be interpreted by a computer or other device. Without the module, the pads and cymbals will not produce any sound or trigger any MIDI data. Unfortunately, it is not possible to bypass the module and connect the USB cable directly to your laptop. You will need to obtain a replacement module in order to use the drum kit.
Jul 20, 2022 • The Music
tip
Studio Recording at Home; Part Deux
This tip, continuing the series of Home Studio Recording, focuses on the hardest part of accomplishing this feat: Drums.
A big sound killer on 'budget' recordings is poorly recorded drums. There is a remedy, though. If you have one set of drum mics, buy another (or borrow. This will come into play later, though).
If you have clips that hold them on the drums, great. With the two sets, you'll only use half of the clips. For the rest of the mics, you'll want stands. You'll need one stand for each drum, plus six.
The dual mics serve this purpose: To capture the sound of the whole drum. One mic for the batter head (the side you hit), and one for the resonator (the side you don't).
For the batter head, you'll use the mic clips, and attach the mics as you normally would during playing. For the resonator head, use the stands to position the mic directly across the drum, making a straight line from the top of the drum to the bottom. This will help eliminate any voicing differences, which can be a real headache.
For the bass drum, you'll need 2 stands. Position the batter head mic close to the edge of the head on whatever side is easiest to access, but is also comfortable for your playing style.
Aim the mic so that it is pointed at a midway point between the center of the head and the edge. You can experiment with different spots, but be sure to NEVER let the mic be directly in front of the head.
For the bass resonator head (the front one that everybody sees), position the mic so that it is a mirror image of the batter mic. Once again, this gets rid of voicing problems.
You have just miked your drum kit, but what about cymbals? That's where the other 4 mics and stands come into play. Those 4 will take care of:
Hi-hats
Ride
Overheads
For the hi-hats, you'll want to position the mic about 3-5 inches from the top, and 2-4 inches from the side. It's best to come in from the outside of the kit, so that you'll pick up a bit of ambiance (the rest of the kit, as well as some natural reverb). Point the mic at a point close to midway between the bell and edge of the hats. Too close to the edge, and you'll get a sound similar to banging trash can lids together. Too close to the bell, and there's too much high-mid noise that CANNOT be reduced with an EQ.
For the ride, follow the same instructions for the hi-hats, but add about 2 inches to the distances. Aim the mic a little closer to the center as well, so that the mic will pick up any bell hits. A good spot is 1/4 the distance between the bell and edge.
Now for overheads. These are the mics that not only record the cymbals, but pick up the most ambiance.
NOTICE: I haven't already mentioned it, but you do NOT want to record with the drum kit up against a wall, nor do you want it in the center of the room. For best results, use the midway rule (as with placing mics on drums and cymbals, place the kit midway between the center of the room and the edge, preferably headed towards a corner). This will reduce unwanted echoes in the room due to sound reflection.
You will want to place the overheads about 1.5 feet above the highest cymbal. Space them out so that the entire kit is between them, but be sure to keep them evenly spaced. You'll want to use the snare as a midway marker for the placement of overhead mics, since it is your loudest drum, and more likely to be picked up in the overheads than any other drum. This will also keep the snare panned center (you'll be panning the drums out to the left and right later on the mixer, but the snare and bass stay center).
These are some guidelines for setting up mics for recording drums at home. I hope that helps, and stay tuned for Part Trés of Home Studio Recording.
on Mar 13, 2011 • Music
My Simmons SD9K will not save my drum settings? Any clues as to why it won't save anything?
I found this. It appears to have a motherboard battery that saves settings once powered down.
My SD9K brain module forgets/randomly changes the settings of the custom kits I create. Possibly an issue with the internal battery? If so, what type of battery is this and are they available?
Yes you would need to replace the CMOS button battery on the main board of the system.
And also this
You either have to hook your computer up to it or use the SD card or usb disk. You must leave it plugged into your computer to use the midi feature. You also must have a program that does midi. Or put it on a card or usb and use it that way. You must have it plugged in to the computer, card or usb to use it. You cannot save it to the brain.
https://www.google.com/search?q=Simmons+SD9K+will+not+save+my+drum+settings
Simmons sd9k has no display.it lights up,no print
I fixed mine it had the same issue bye opening it up by taking the screws out and carefully open it up and look for any corrosion or buildup on the circuit board then take a q-tip and dip it into isopropyl alcohol rubbing alcohol and just clean up any corrosion on the boards then look for the ribbon cable connection that is connected to the display try pushing the connector in to make sure it's firmly set in there on both ends of it and put it back together. I don't know what caused the screen to not display the actual text because I bought it used at a swap meet but I tried this and it worked.
1helpful
Simmons sd9k LCD/brain issue?
The display is usually held against the circuit board with 2 or more strips of multiconductor rubber. it may just need the clamping tabs tweeked to make a more secure contact. If the drum set fell, it could have shifted the circuit board in relation to the display. Parience and careful observation will allow you open it up and make that tweek.
Simmons SD9K control panel only lights up
Mine and a whole lot of others did the same thing with the SD9K Simmons kit. I called Simmons, they sent me a new power cord...that obviously didn't work. Then they said to wait on a new drum module...that never came. It's been 2 years and now they say they have no records of ever talking to me or sending me the power cord!!! Horrible product, horrible customer service. Whatever you do...don't put any more money into Simmons...only go with Roland!! Trust me on this one!! Me and about 3 others I know waisted $900 on Simmons and we are all paying the price now. So, to answer your question, you need to buy a $300-$400 new module!! Ridiculous!
2helpful
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
1helpful
WHEN I STRIKE THE BASS DRUM, THE CRASH CYMBAL SOUNDS AT THE SAME TIME....EVEN WHEN NO CYMBAL IS CONNECTED TO THE INPUT JACK.
If you leave an input open they MAY cross couple... try plugging a set of headphones into the cymbal input jack... this will ground the cymbal input... then see if you still get the cymbal sound... IF you STILL get the sound, then the multiplexor that scans the input has a problem and you need to take it for repair. Repair on the surface mount boards is not a DIY without proper tools and skills. If the grounding stops the cross coupling, then you MAY have a problem with the cymbal or its cable.
One of my cymbals just stop working, i've unplugged it from the cymbal, turned the amp off and on, restarted the system and nothing seems to be working. I did unplug it from the "brain" i believe, (i just...
Try these:
- change the interconnection cable between the cymbal and the "brain" unit, if the problem goes away, you have a bad cable.
- if the problem persists, see if that particular cymbal works well on another input of the "brain" unit, if it does, you have a problem with the input on the "brain unit", this will require servicing if the unit still has a warranty, otherwise you should first check the solder contacts on the input that doesn't work (also check for dirt /oxydation on the plug contacts and clean if necessary).
- If that particular cymbal won't work when you plug it into any "brain" cymbal inputs (it's basically a piezo trigger so it should work on other inputs), then you have either a broken wire on the piezo trigger or on the cable connector in that cymbal (it should be possible to resolder), or the piezo trigger itself is faulty and needs to be replaced.
I hope you can find out what troubles your drum kit.
regards
3rq8 (triarcuate)
3helpful
Where to connect 3rd cymbal cable end to drum machine
well i am not sure what r u talking about,but as i met the same problem,i assume that you mean you lack one cable...What you should do is:
1.Connect the cable to the cymbal.Then connect it the ending of the cable with bass drum(not with the device)
2.Connect the bass drum with the device,as there will be 2 cables in the bass drum.Then plug it into the device & you will be ok.
Top Simmons Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Simmons Music Expert? Answer questions, earn points and help others
