SOURCE: Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
SOURCE: Doesn't work at all!
Daft question, but are the batteries fully charged?
Lens cap off?
When you hit the menu/ok centre button, do you get the menu screen up?
SOURCE: finepix s5700 date stamp wont show on my computer
Guru, would you describe where in the menu that function can be found, 'cause I can't figure it out.
Thank you.
SOURCE: my FUJI FINEPIX S5700 Digital Camera keeps saying
You may not be able to. However let us try. Reset all menus to default, or factory settings. Another way to do it, possibly is to remove all batteries and let the camera sit for at least 24 hours, then put the batteries back in and try it.
You may need repairs.
