I want to install Cydia on iOS 9.3.4 but want to know how can we do this without using computer. I mean is there any specific code I have to insert or something available in settings area?
It's impossible to download and install CYDIA without a P. C.
First , your i device must be jail broken and that to requires a computer. The real Cydia by Jay Freeman (saurik ) can only
be obtained with a jailbroken I device using a software tool like
Pangu ,or TiAg.., or Evasion . These are downloaded free of course using your idevice only and will only open and work when you plug into a p.c. with a USB cable from that I device. SORRY.
There are some emulators you can install and there is a Cydia on one of these apps and is called - inocydia.net . But there are a couple of things you do to get the app . And is ok actually because there are some apps in these stores as well that are useful to me ,
although they may not be useful to you ,after you get the
Web apps app stores and the inocydia app , you can delete the others that will be needed for the Cydia web app.. I use them and are perfectly safe to use . I use to have Cydia on one of my iPad 2 . I have many i devices and although the one I'm referenceing To is jailbroken still I opted after 3 years to delete Cydia. It's a pain in the rear , it crashes constantly , you have to jump through to many hoops to get a tweak ,or add this then add this to complete a
complete a theme , Blah blah blah .....to me........its to time consuming and so frustrating, to fix or respring and reset all the settings and wifi code than to get an app and use for few days only to tuck it in a folder i call "Rarely used apps I hate " or the other
folder that I labled " kicked to the curb " that when in this folder , these apps will never see daylight again . I only open it to put things in .......never to come out .huhuhaha
So if you want the links and the procedure or steps to download and install these useful App Stores Alternative s , follow up on my answer to your post ...and this way I will provide all the links and direction for download and installing . It's a bit tricky in the order of what step is used but very simple in the process . So there Ya go
and I hope this will help .. Best to Ya .later on MUCHACHO,
A. Goodwin
