The phone is a Binatone landline purchased in Argos Designer 2115 VT 1211 001483g
SOURCE: Philips C150 landline phone. It
Do a power on test. Reseat the battery and check if it starts working. Does it indicate good battery and signal strength.
SOURCE: No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
www.cordless-phones.uk.com
SOURCE: Cordless phone e3300 Binatone blocked
A friendly person sent me a manual for the e3300 and I managed to correct the problem.Thank-you for your concern and support.
SOURCE: Nokia N72 mobile phone, am unable to hear dial
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
SOURCE: landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
