Modem keeps dropping offline
Cordless phones, microwave ovens and wireless surveillance cameras between the modem and the device will do it. If it's hard wired to the computer, the signal strength from the phone company may be low. Call the phone company to have them come out and test the signal level that is applied to the modem.
SOURCE: I have a NetGear WNR834M
I too experience a similar issue with the wireless connection dropping. My wireless devices are within a 20-30 foot distance from the router and all of the devices loose conectivity so I know it's not just a specific device.
My WNR834M is running version 1.4.23NA. The logs file doesn't show anything except for one timestamp the last time it was reinitialized (a forced reboot).
The router's WiFi Channel is set for AUTO and is currectly using Channel 1 (found under Maintenance
SOURCE: netgear dgn1000 modem router keeps dropping out
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
do a hard reset for netgear modem
