Question about Chef's Choice Cordless Electric Kettle 681 - -
The on/off switch now does not stay in On position without manually holding the button down. Also the kettle sticks to the base when its lifted up.
The kettle worked fine for ~3 yrs. Coincidentally both these issues started almost at the same time. Are they related. Any easy fix?
  • 388 Answers
Need yo replace the switch its faulty inside
Posted on Oct 03, 2016
2 Suggested Answers
6ya staff
SOURCE:
David Garrod
  • 5 Answers
SOURCE: My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Posted on Feb 18, 2012
Fugitronic automatic dispensoing hot water pot won't heat
The partial answer to your stated problem is that after 3-4 years of use it is possible that the heating element has worn out
Mar 08, 2013 | Fujitronic Automatic Dispensing Hot Water...
Sound stops and starts on youtube
Step 1:
Restart your computer. Once your computer is completely turned on, check if youtube is working fine. If no go, please proceed to next step.
Step 2:
Use a different web browser like chrome or mozilla. Check if it works. This is actually a problem with your web browser. If I were you, you update your webbrowser or the flash player. Flash player runs videos and music in the web browser.
Step 3:
After fixing this problem, download Radarsync so that all driver related issues are fixed. Your current issue could also be a cause of a driver related problem.
Dec 06, 2012 | Computers & Internet
Have a sony hdtv about 6 yrs old. when i turn it on the green light blinks then turns to red, blinks 3 times and shuts off. help!!!!
This is a problem with the projection lamp. It is an easy and relatively cheap fix. http://www.google.com/#q=sony+wega+lamp&hl=en&prmd=ivnsfd&source=univ&tbm=shop&tbo=u&sa=X&ei=TbRXTrqcBcnUgAfq5am8DA&ved=0CI8BEK0E&bav=on.2,or.r_gc.r_pw.&fp=2c2772292abb57a2&biw=1280&bih=892
Aug 26, 2011 | Sony Televison & Video
LG 42lb1dr remote control quit working. Changed
The Main Boards in these sets have caused remote control issues and could also cause the Reserved indicator to light. You will need the Model number, and the extension letters and numbers to the right of the Model Number to order the board. I would also have the Serial Number just in case it is also required.
Hope this helps,
Skyassoc
Dec 26, 2009 | LG 42LB1DRA 42 in. LCD Television
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
Won't turn on
I have the same problem. It started about a week ago and I have to keep flicking the on switch to get it finally working. I think there's a problem with the contact with the base. Not sure if it's worth getting a replacement part for it. It worked well for 4+ yrs!
Apr 20, 2009 | Braun WK200 AquaExpress Electric Water...
How to descale Philips HD 4651/C Electric Water Kettle
Not having received any solution message from FIXYA contributors, I consulted with a family member
and also my long held Time-Life Books, Fix It Yourself Library, Volume: Cleaning & Stain Removal,
ISBN: 0-8094-7400-X, Copyright 1990. My issue was resolved by using white vinegar and soaking the internal problem area for 30 minutes. The appliance has cleaned up like new and works fantastic. I apologize for bothering you.
Nov 27, 2008 | Philips HD4651 Electric Kettle
Overheating kettle
this same thing happened to me
Sep 10, 2008 | Bravetti EK119H Electric Kettle
Switches off before full boil
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Chef's Choice Cordless Electric Kettle 681 - - Logo
820 people viewed this question
Top Chef's Choice Kitchen Appliances - Others Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
