LG 47LG50 47 in. LCD HDTV Logo
S
Sandy race Posted on Sep 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lg tv is overfilled, it cuts people off on the top and cuts the bottom off. How do I get the picture to fit the screen
Sotiriadisgeorge
Level 2:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • LG Expert 125 Answers
  • Posted on Sep 23, 2016
Sotiriadisgeorge
LG Expert
Level 2:
Filmmaker:
New Friend:
Answers
125
Questions
0
Helped
35898
Points
134
Its pretty easy check your remocon for the button that writes
ratio press it continiouly until you find the 16:9 ratio
hope you get it right
George (ratio button usually is on top right of you remocon )
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Oct 14, 2007
SOURCE: Picture too large
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Anonymous
  • 4 Answers
  • Posted on Jan 12, 2009
SOURCE: My picture doesn't fit my LG Plasma 42" TV.
Try going to your LG menu , go to screen option and take it off zoom. This could be your problem.
Anonymous
  • 7 Answers
  • Posted on May 08, 2009
SOURCE: LG 42 inch picture does not fit on the tv screen horizontally
The format is set incorrectly. Go into the Picture settings in the menu and adjust the format settings until you get the size picture that you like.
Craig
Anonymous
  • Posted on Jul 03, 2009
SOURCE: Picture outside of screen limits
I have Time Warner Cable and just FIXED this problem. On the cable box remote, there is a button with the word "Aspect" on it. On my particular remote, this is the "#" button (pound symbol) and by pressing that button, it gives you options of "Zoom 1", "Zoom 2", "Stretch" and "Normal". By setting it to "Normal", it completely solved the problem. Oh and by the way, my t.v. is the LG 47" flat screen LCD. Hope this helps the other frustrated folks out there.
------Dave
Anonymous
  • 143 Answers
  • Posted on Sep 28, 2010
SOURCE: LG TV MODEL 442L0520 SERIAL 005RMKUA3341 PICTURE
You need to go into the TV menu and change the settings for the display! Press the Menu button and adjust the Picture! It's probably set to automatic and not reading them correctly.
1helpful
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
My screen does not cover the whole screen. It is not on widescreen mode, but it is a shortened picture and some of what I am watching is cut off.
A lot depends on what the TV station cuts off also.
If they are transmitting a 5 X 4 picture, your TV will try an reproduce it giving cut off edges or top and bottom. It won,t fit properly.
Hope that helps to explain it.
4helpful
2answers
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
1helpful
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Cuts off picture at top of screen and bottom of screen
good luck tryin to find a universal remote i cant...but if you do there should be a button that might say something like pip, pix, screen mode something like that and it will make the picture streach to fit the screen however not all channles will be set on the same screen settings.
16 : 9 overfills screen
on what sd tv or hd tv native is on 16.9 then take zom off or wide fit
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
