-Open the front cover
-pull the old toner cartridge out.
-Remove the new toner cartridge from its bag
-Thoroughly shake the cartridge 5 or 6 times to distribute the toner evenly inside the cartridge.
-Thoroughly shake the cartridge to assure maximum copies per cartridge.
-Remove the paper protecting the toner cartridge by pulling the packing tape.
-Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the printer.
-Tabs on the sides of the cartridge and corresponding grooves within the printer will guide the cartridge into the correct position until it locks into place completely.
-close the front cover.Make sure that the cover is securely closed.
If you need any technical help on printer then you can reach at
http://www.vtechsquad.com/
