Refrigerators Logo
Sunil Patil Posted on Sep 24, 2016
Subzero 695s dispenser light (3 small LEDs) are flashing and the dispenser is not working ?
2 Related Answers
Anonymous
  • 700 Answers
  • Posted on Jan 16, 2009
SOURCE: Subzero 685 water dispenser won't work
check the water resevour it is probebly frozen up arpound the outlet of it. its inside of the refrigferator, towards the back of the refrigerator down towards the bottom. take a hair drier and thaw it out.
Anonymous
  • 553 Answers
  • Posted on Nov 14, 2009
SOURCE: fridge side light is off. fridge works
check if your bulb is busted, have it replace
1helpful
Subzero 695 Ice/Water dispenser problem.
maybe ice formed around chute from leaky air seal??? warm area with hair dryer blowing hot air up into chute for 10 minutes. check for water and wipe all off. unplug refg and plug in after 3 minutes to reset electronics
if helpful please rate me. if not please tell me more.
tip
How to Reset Your Water Filter Light
<b>Amana:<br /></b> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>auto light</b> buttons on the dispenser for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>After replacing the water filter, press and hold the Reset Filter pad for 3 seconds. The Order and Replace indicator lights will blink and then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br /> <ol> <li>Press firmly and hold start button for 5 to 10 seconds.</li> <li>Four bars will appear in the display, one after the other, and flash. Do not release the start button until the 4 bars appear and start to flash. If you have difficulty pressing the start button, a capped ballpoint pen may be used to press the button down.</li> <li>A small flashing dot in the lower right corner shows the indicator is working.</li> <li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li> <li>After 2 months, when all bars have disappeared, an arrow will flash at the top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b> <ol> <li>Press and hold the <b>reset </b>button on the dispenser until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol>or<br /> <ol> <li> Press the reset button on the dispenser for 4 to 8 seconds then release. </li></ol><b>Hotpoint:<br /> </b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol> <b>Jenn-Air:<br /> </b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b> <ol> <li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br /> </b> <ol> <li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b> <br /> <ol> <li> Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol> <b>Maytag:<br /></b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br /> <ol> <li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br /> </b> <ol> <li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li> <li>Release the buttons and repeat the same step one more time. The water filter indicator light should turn green.</li></ol>or<br /> <ol> <li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br /> <ol> <li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i> buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol>
on Jun 17, 2011 • Refrigerators
Cannot get a connection from wireless internet to game-
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
1helpful
One flashing red light on xbox360 ( not red ring)
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
6helpful
2answers
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
4helpful
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
3helpful
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
2answers
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
