Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX ... 1. soft reset - is just turning tv off & back on 2. hard reset - unplug power to tv for 1 minute then connect power to your Flat-Screen
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding ... I get a center led light when its plugged in showing power. ... I have a dynex 42 in and it dose not have stand by but turning on on the light but nothing happens ....Repairing Flat Screen TV - Blacked out with blinking red light ...
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If this is one of the first lcd TVs that set on a stand and are bulky in the back of the tv there is a place to change the tube it is a box and you will have to change it you can get on eBay and order the part I have one and have changed it a few times what happens to them is it comes in a box and if there is a power outage the little fan can't cool it off and they go bad if you still have your ouner ship booklet it will have instructions on how to change it isn't to bad to do
hope this helps
A lot of people are confused about turning the TV 'off'. If there is a light showing when the TV is 'off' it is merely on 'stand-by' and not truly off. Off means being physically turned off by either the switch on the set or the mains. using the remote to turn 'off' the TV will not turn off it will only put the set into stand-by mode. In many cases if the TV is in stand-by mode, and then switched off, when the set is turned back on, it will still be in stand-by mode, and will need to be turned on with the remote. (even if you unplug, in some cases) All TV's are different, so will operate differently of course.
There are some capacitors on the main boardthat are low quality. You can
buy a capacitor repair kit on Ebay that contains a set of capacitors to
replace the offending ones - about 15-16 bucks. I soldered in the new
capacitors and the TV has worked perfectly since.
wont turn on red light just flashes? On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
