Printer paper jams before the tonner.and also displays the error as "13.05.00 JAM INSIDE TOP COVER ". I checked with another toner. The problem is not yet solved . Pls do needful.
It happens form both: manual feed and tray... sensors don't look misplaced.
This problem happens when you print from "Manual Feed" or "Tray" ? It might be some sensor broken or misplaced.
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
I just have the exact same problem... anyone? please?
same problem
exact same
Laser jet 2420 printer paper jams before the tonner.and also displays the error as
problem is not yet solved, also change fuser unit still no success. Can anyone help me please.....
Laserjet 2420 printer paper jams before the tonner.and also displays the error as
problem is not yet solved also change fusing unit and still no success. Can anyone help PLEASE....
exact same problem, all is clean, snsors look ok too.
Will not print. Says 13.05.00 JAM IN TRAY 1
paper jam problem and this error 13.20.00 jam inside top cover
