SOURCE: Changing the time on an LCD Digital Watch
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Malcolm S
SOURCE: need to reset time
Just open your watch then look for negative and positive connection,then short it,for 3 seconds then it will reset all.
Hope it may help you;
Regards;
VOTIT
SOURCE: Hi I have a boys digital watch umbro brand and I
Press 'mode' (bottom left) three times until the seconds at the bottom of the display are flashing. Then use 'reset' (bottom right) until the part of the time you want to change is flashing. Then use start/stop (top right) to set the time. Use 'reset' to scroll through to the end.
SOURCE: Umbro U333 watch. I need to know how to set time.
Thanks for contacting FixYa.
You can find manuals and instructions at the following link:
www.bulovaspecialmarkets.com/service/servicecenter.aspx
Best regards. Jewel
SOURCE: i need instructions for digital
Go to this web site it should help:
www.buydakotawatches.com/PDF_FILES/Digital.pdf
