Question about Sony BRAVIA KDL-40V3000 Television
My tv model KDL-40V3000 SOME CHANNEL ARE GREAT NO PROBLEM, BUT OTHER CHANNELS LIKE 2, 4, AND 11 am getting mess up picture, colors and picture are smear like it freezes and double shadow
Sony Bravia KDL-40V3000 SERIAL NO. 8027645
    Top Expert:
  • Sony Master
  • 76,177 Answers
Check and replace its tuner.
Posted on Sep 27, 2016
6ya staff
SOURCE:
Anonymous
SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
Anonymous
  • 4 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
Posted on Jul 08, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
mcraig31
SOURCE: How to fix problem with Sony TV.When turn on sony
I just fixed one with the same problem. The light flashed 13 times.
I had to cut one trace on the hv board to one of the lamp drivers.
There is a slight but barely noticeable darken line across the screen but the tv stays on now and the picture is good. I don't
know if the lamps can be replaced but why bother now.
Posted on Jul 01, 2010
  • 6048 Answers
SOURCE: Can not change the channels on my Sony Bravia
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Posted on Sep 11, 2010
KDL-40V3000 program not tuning
if possable retune with a known working connection ie at the house next door
this will rule out your own setup and may save you time / money in the long run
May 15, 2012 | Sony BRAVIA KDL-40V3000 Television
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
How to fix problem with Sony TV.When turn on sony Bravia TV KDL-40V3000. It comes on and then turns off,
Jun 29, 2010 | Sony BRAVIA KDL-40V3000 Television
How do you watch free cable channels on a sony
If you are connecting the cable directly to the TV with no cable box, you'll select Home on the remote control. This will put the menu on screen. Scroll down until you find the Channel Settings option. Set the Cable category to On, Select Auto Program to automatically scan for all analog and digital channels. You can then customize which channels you want to remove when scanning channels.
Feb 10, 2010 | Sony BRAVIA KDL-40V3000 Television
I have a Sony KDL-40V3000 with a single verticle green line going down from top to bottom of my screen on all sources. Otherwise the picture is great. TV is out of warranty so any advice would be very...
This is a fault with the panel or one of the surrounding boards, you need to contact a Sony service center as there is no easy solution.
Just to warn you, it will be costly....!
Thanks
Oct 09, 2009 | Sony BRAVIA KDL-40V3000 Television
Noticeable line through screen picture sony KDL-40V3000
TRY USING THE COLOR CONVERSION OPTION ,,ITLL FIX THE COLOR
Mar 07, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony bravia kdl-40v3000 blurry news ticker
without going to hd, contrast to full, color, tint and brightness to middle, then adjust sharpness for optimum clarity
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony 40V3000 - Ghosting whilst viewing via SCART (Freeview is visable through picture)
have you tried plugging your sky box into another scart socket on your tv set
Mar 11, 2008 | Sony BRAVIA KDL-40V3000 Television
On Timer - channel selection
The on timer will only work for a channel on this model not for any other inputs
Mar 04, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-40v3000
NISK-TRY USING YOUR DIRECTTV MENU AND LOOK AT THE SCREEN FORMAT SETTINGS AND MAKE SURE YOU ARE AT 16X9 SETTING.JOETV
Dec 21, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
