How do I find the settings for photo storage e.g. BMP or jpeg. I have a hard copy of the manual
SOURCE: format, cant open photos, cant take photos
Hi there.
The camera is asking you to format the camera card.
If you have any pictures you want on the card, connect it to a PC and transfer the data from it, then put it back in the camera and do what it asks you too do.
Thanks for choosing FixYa!!
SOURCE: it takes so long to process after I take a photo,
The Samsung L730 is Intelligent LCD brightness,it automatically detects environmental illumination and adjusts LCD brightness for optimal image viewing. no problem it just working fine
Testimonial: "Thanks :) I guess I just need a new camera then....it takes up to 2mins to process and the photos that take the longest are not of great quality"
SOURCE: Samsung TL220 storage issue
If you format the camera without the memory card inserted, the internal memory should be erased. Then, making sure the slide switch on the side of the card is in the unlocked position, insert the card and format it. Things should work after that. If they still don't, go into the camera menu and find "reset"...follow the on-screen instructions.
SOURCE: Photos taken outside are all white
Please try to put camera on AUTO in the settings and then see the results. It should give you the desired results.
SOURCE: how do i set my
You want to set the Self-Timer ... to delay the shot, say, by 2, 5, 10 (or a specified number of) seconds, assuming your camera (model) has that feature/capability. Which camera (model) do you have ?
