Toshiba E-studio 282 Copier-scanner-printer-fax Logo
b
berty kaldas besada Posted on Sep 29, 2016
The counter of my toshiba e studiob/w doesn't count the cpies .It's always 0 . How can I fix it?
1 Related Answer
didi2005
  • 727 Answers
  • Posted on Feb 13, 2009
SOURCE: wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to reset pm counter toshiba es 356
Power "OFF" the copier. Press continously "0" and "8" while turning on the power. From the screen it will show AD mode. Press "252" then "Start". It will show some numeric values on the screen, " this is the past PM count ". Press "0" then "Start" or "Interrupt " key then power off and on the copier ..
Toshiba studio 181 error c44
This error indicates that the print count has gone above the limit and it requires service. But, this is not necessarily true. Try the following to reset the count:
Solution:
  1. Switch off the printer first.
  2. Now Power the Printer by pressing 0 and 8 keys (keep pressing).
  3. Then a test mode comes up.
  4. Now Type 400.
  5. Press START (!)(You will get a counter and now you need to reset this).
  6. Type 0.
  7. Press Enter(start)
  8. Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
  9. Now switch off the printer and on it normally.
  10. You should see printer working normally
Resource: Clear Toshiba eStudio printer error message Error C44 call service
I need to reset the maintenance counter on a toshiba eStudio 225
1. Key in "0" for 08-6198 (Switching of output pages/driving
counts at PM [process unit (K)]).
2. Key in the value of the number of prints for the PM display
other than "0" for 08-6190 (Setting value of PM counter
[process unit (K)]). in case of anything you let me know
Drum life warning on toshiba dp120f
reset drum Counter for DP120
Turn fax off. Hold down 0, 1, 3 on numeric key pad and turn fax on. Then release the 0, 1 & 3 and enter the number 80, wait a few seconds and should see a message confirming counter has been cleared. Then turn fax off and on again
1helpful
2answers
How can i check the copy counter of toshiba e studio 181 copier machine
Date:06/04/2013Sir
My digital copier toshiba 181 showing page counting 179113 but when doing copy the previous reading is not increasing , it is stopped in 179113. could you give me suggestion to(Programe) reactivate the page counting.
Thanks
Golam Rabbani
Chittagong, Bangladesh
1helpful
2answers
The waste ink absorber is almost full How do I fix it Please?
It needs to go to a shop to have the absorber changed and the counter reset. Only a Canon shop has access to parts and service mode to reset the ink counter.
1helpful
2answers
Wrong count
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
