Question about GE GTWN4250MWS 27" Top-Load Washer, 3.7 cu. ft. Capacity, EnerStar Qualified, HydroWave Wash
GE Hydrowave top loading washer is leaking around the top side and back of unit when filling.
    Top Expert:
  • GE Master
  • 53,755 Answers
Check for the water outlet from the water solenoid control valve
it may be displaced or broken and not directing water to the bowl
Posted on Sep 30, 2016
6ya staff
SOURCE:
Anonymous
  • 89 Answers
SOURCE: How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Posted on Dec 15, 2007
Anonymous
  • 487 Answers
SOURCE: ge front load washer leaks from bottom
full display
And for the part numbers look here
Have fun with it and please rate me on this site
Posted on Apr 20, 2008
chris weier
  • 82 Answers
SOURCE: Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Posted on Jun 19, 2009
Anonymous
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: GE WBSR3140DW Top Load Washer Repair manual
Check your local Appliance Parts Stores, they usually have racks of repair manuals.
Posted on Nov 25, 2009
Top Loading Hydrowave. Washer fills but won't agitate. After a few minutes water is pumped out and it spins normally.
It almost sounds like the lid switch is working backwards but I have never seen that happen on a GE. The switch either works or goes bad. One other possibility is a defective water level switch. Thats also called a pressure switch sometimes.
Apr 17, 2015 | GE Washing Machines
My Ge Top load washer will not power up start button?,no lights.
Their is a fuse in the harness red wire that runs down from the control to the motor on the hydrowave washer. Hydrowave washer manual
Of course if yours isn't a hydrowave maybe you oughta post a model number. GE has several different styles.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 09, 2013 | Washing Machines
GE hydro wave won't agitate
HYDROWAVE SERVICE MANUAL
Read this first then let me know your status
Jul 17, 2012 | GE WBSR3140DW Top Load Washer
Washer won't cycle past fill, keeps returning to fill cycle
That could be excess detergent causing the control to do extra washes to get rid of detected Suds. On these washers it is critical to use HE detergent and the right amount. Most often directions on detergent boxes are useless. This washer has a 3 phase motor with an inverter to change the current from 120 to 200 volts dc. If you continue to use wrong amounts of detergent the inline fuse will eventually blow from the motor overheating trying to correct overdose of detergent. Read more about it in the GE HYDROWAVE SERVICE MANUAL
Apr 24, 2010 | GE WHRE5260E Top Load Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Purchased a GE washer WHRE5550kww need to know why it isn't filling to the top 'holes' when set on large/super wash?
Hello....I don't know the answer to your question, but would like to know if you like this machine in general, are you happy you bought it??? Would you buy it again? Thanks
Aug 04, 2009 | General Electric WHRE5550H Top Load Washer
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
GE GTWN4250MWS 27" Top-Load Washer, 3.7 cu. ft. Capacity, EnerStar Qualified, HydroWave Wash Logo
189 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
