Clymer Suzuki 2-225 HP Outboards Includes Jet Drives 1985-1991 Logo
Tony Harris Posted on Oct 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1993 Suzuki 4hp 100.1 how much oil per gallon
Bill Boyd
Level 3:
Top Expert:
  • Clymer Master 53,816 Answers
  • Posted on Oct 01, 2016
Bill Boyd
Clymer Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925843
Points
172802
The manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
3 Related Answers
Anonymous
  • 2336 Answers
  • Posted on Nov 10, 2008
SOURCE: Miles per gallon
I just purchased a 1995 VS 800 w/18,000 miles and it gets 50-60 mpg at 60 mph.
tombones
  • 3567 Answers
  • Posted on May 05, 2009
SOURCE: how much oil per gallon of gas
A fuel mix of 32 to 1 is the standard. That means 4 ounces of oil to one gallon of gas. Be sure to use two stroke engine oil in the gas. DO NOT use motor oil. 10w40 motor oil is for the gearbox.
A top rating would be nice. Thanks!
Anonymous
  • 19 Answers
  • Posted on Mar 20, 2011
SOURCE: On 2007 suzuki gsxr 600 - how many miles per
depends on your riding...40 if you haul ***! 47 if conservative, and possibly im not sure but you could get 52 if you derive like a car..but who drives a bike like a car? so i would say you get 45 miles avg.!
1helpful
3answers
What is the petrol mix for stihl fs90av electronic strimmer
80 MLS of 2 stroke oil to one gallon of fuel and it doesn't matter what octane, of course the higher octane is better cause it burns cleaner. To much oil will gum up your carburetor and engine.
2answers
Fuel mixture
if its 2 cycle the mixture can be several mixes. it should say on the machine. here are the following mixtures that I have- 16-1, 1 gallon of gas to 8 ounces of oil. 32-1, 4 ounces per gallon. 50-1
3 ounces per gallon and 100-1 2 ounces per gallon . most of my 2 cycles are 50-1. hope this helps.
Nov 29, 2015 • Garden
2answers
What kind of oil does a 1993 Suzuki Katana 750
Depends on the mileage. If it is high mileage, use synthetic.
Sep 17, 2012 • Motorcycles
2helpful
I need to know the fuel/oil mix ratio for a bolen bl 100 31cc trimmer.
You should use 3.2 fl oz of 2 cycle oil for every one gallon of unleaded gas or 100 ml per 4 litres of gas.
Apr 28, 2011 • Garden
5helpful
I have a FORD Econolinen 1993. When I drive he abuse 45 ltres of gaz on 100 miles . Is this normale ?
on normal that trk should be around 6-7 gallons used per one hundred miles drove. i based that at 15 mpg. now that is also based on a V8 engine. now 1 gallon of gas is 3.78541178 liters which totals 12 galons of gas to 45.42494136 liters. This would mean that it took 12 gallons of gas to travel 100 miles which totals 8.3333333333 mpg. not as good as i would have thought. 8 miles per gallon (mpg) hell that engine must be a big block 460. If it is that big cubic inch i could understand but any other motor should do better mpg than 8.3. so i agree that is not normal, tune up, or look for fuel leak in the fuel supply or( feed ) line. From the tank to the motor. This must be a canadian truck yes? well hope for the best or trade that guzzler in for a new breed. stay warm!
1helpful
2005 suzuki rm 250 fuel mixture
32 to 1. That means 4 ounces of two stroke engine oil per gallon of gas. NEVER use motor oil.
3answers
KTM pro Series .......... what is the ratio for gas and oil?
What model???
Almost all dirt bikes are 32:1. and then jet to get a brown colored plug.
I need to know the oil to gas ratio for my 82' Suzuki RM 125 2-stroke bike.
the correct ratio is 32:1. thats 4 ounces of oil for every gallon of gasoline. if your riding it hard or in very hot wweather, you can even go 28:1, or 5 ounces to a gallon. dont go any less, or you risk damaging your engine. and dont use more then 5 ounces per gallon, or you willl have poor performance. the manufacturers back then reccomended using very high amounts of oil, like a 20:1 ratio, but with our better technology and more advanced oils, that is not neccessary. just remember, either 4 or 5 ounces to a gallon, and both you and your bike will be happy.
1helpful
Two stroke ratio
The standard ratio is 32 to 1. That equals 4 ounces of two stroke oil per gallon of gas.
Top rating Pls.
1helpful
Was given partner 1612 chainsaw and need to know gas/oil ratio please. thanks
50:1 2.6oz mix per gallon or 100:1 about 5 oz per gallon
May 12, 2009 • Garden
Top Clymer Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Clymer Boating Expert? Answer questions, earn points and help others
