SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
SOURCE: drain problem in GE WBSE2090A washer
hello, if you washer is not or isn't fully draining that sounds like something might be in the pump.Icheck for any hose blockage as well.If there is a bad smell that might be dirt or a peice of clothing or anything. so my suggestion is to check your drainage hose, the pump or maybe try even to syphan out the pump which means put the drainage hose in a bucket lower than the washer or your drainage is higher than the washer. good luck...
SOURCE: GE Washer fills but will not run through cycle
Sounds like a bad motor. It's likely shutting off from it's internal thermal switch. Try unplugging the motor's molex connector and replugging it, it could also be a loose connection.
Good luck.
SOURCE: washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
SOURCE: 2008 GE PROFILE WASHER. THE WASHER WILL RUN
You need to replace the "lid switch". Here is a link to the part you need. Here is a link to a video that may help you.
