SOURCE: Radio Shack Digital Answering Machine Cat #43 3825
No problem, follow the below link for your manual. http://support.radioshack.com/support_phones/doc72/72809.pdf Good Luck L8R
SOURCE: Radio Shack Sprint SP-812 Answering Device can't retrieve messages
Follow the below link for your manual,
http://support.radioshack.com/support_phones/39764.htm
The F it is displaying means current memory is full, I would reccomend playing your messages and then recording them onto a portable cassete recorder, or even play it back and record it onto your pc if you have a mic.
hope this helps
SOURCE: Recovering Deleted Messages on Answering Machine
how do you check my messages from another location?
SOURCE: radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
