Correct freezing temperature as ice forms quickly
SOURCE: upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Thank you for your inquiry, Herb!
I see that your Frigidaire refrigerator, FGHB2866PF, is not making enough ice. When is the last time you changed your filter? It is recommended to change your filter every six to nine months. If the filter is dirty the icemaker will not produce. You may also have a frozen water line and you can perform a manual defrost in order to clear out the line. To manually defrost your line you would need to disconnect power from it for at least three to four hours. If that does not correct your issue you may need to have a professional technician out to perform a diagnosis and repair. I hope this information is helpful. -Matt
