Question about Brother MFC 240C All-In-One InkJet Printer
Brother mfc-240c printer beeps on fax light then makes some sound, but dont show that its connected to the computer
The printer beeps and makes some noise, i can't turn it off with the power button, when I plug it back on it makes these three beeping sound and a noise like a snap. what can I do?
6ya staff
SOURCE:
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: How to connect MFC-240C fax/printer to my computer
http://www.nodevice.com/driver/MFC-240C/get41297.html
from this link you have to download th edriver for this device ...
after that if it has a usb cable or a regu;ar printer cable ...conect it to the pc
when its plugged well you will hear a bel sound from the new device found wizard...
ya may also run the driver first ...so in the moment that you plug the printer you already have it into your pc..and the wizard will just complet the installation
Posted on Jun 08, 2009
livetech
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
Anonymous
  • 787 Answers
SOURCE: I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Posted on Nov 06, 2009
ctnozil
  • 270 Answers
SOURCE: paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Posted on Dec 12, 2009
Jimsta01
Jimsta01
  • 405 Answers
SOURCE: where is the usb port to plug in the printer
It is located under the scanner cover, under the glass, if you look at the right side of the machine there is a groove to place your figer to completely open the cover, the USB cable would be located on the right side.
Posted on Jul 15, 2010
How to scan to an external hard drive from brother printer
Can't get the Brother MFC-240C printer to print. I have everything connected.
Oct 29, 2012 | Brother MFC J6910DW - Multifunction fax /...
How to clear the memory on a brother mfc-240c-- error when faxing is out of memory
You can also try to send the fax with Real Time Transmission ON so that memory will not be full.
Sending in real time for all faxes
a Make sure you are in Fax mode . b Press Menu, 2, 2, 3. 3.Real Time TX Realtime TX:On
c Press a or b to choose Realtime TX:On or Realtime TX:Off.
Press OK.
Please click Yes if this helped
Thanks,
vikroks
Feb 05, 2011 | Brother MFC 240C All-In-One InkJet Printer
I have a MFC-240C printer/fax, and I am not sure how to connect it to my computer. I am not even sure if it does connect to my computer! Can someone explain to me how to connect the printer to my PC?
The Printer has to be connected on the port of your computer which is available behind your PC Cabinet.
I have pasted a link for manual which will guide you connect and load drivers and software of your printer.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
It is very easy to connect and get started, so do not worry.
Cheers
Nov 02, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
Jun 07, 2009 | Brother Multi-Function Center MFC-240C...
Fax machine wont fax out or in.
Check an make sure the phone cord from the wall is plugged into the back of the machine in the port marked "line" and not "phone"
Jun 12, 2008 | Brother Multi-Function Center MFC-240C...
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
107 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
