SOURCE: how do you derestrict a 33bhp mz mastiff 1998
The most common way is move the throttle cable from position one to position two. Check to see if this method will work for you by watching the throttle mechanism at the engine while an assistant turns the throttle (engine not running). When the assistant can turn the handle no farther, see if you can push the mechanism open farther with your finger or a screwdriver. If you can, then you will be able to derestrict the bike by repositioning the cable.
SOURCE: i replaced the starter relay
When you push the start button and the relay clicks the lead from the relay to the starter should have 12volts. If it doesnt you either the relay is bad or the cable(lead) is bad from the relay to the starter.Hope this helps.
D.
