Motorola Mobility H700 Wireless Headset Logo
a
aggie Posted on Oct 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change my battery on h700
How to change battery
  • Official Brand Answer 1,623 Answers
  • Posted on Oct 06, 2016
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350724
Points
5677
Hi Aggie,
So sorry to hear that, let me tell you that we don't longer manufacture those devices but if you are able to find a battery in a third party site like Amazon or best buy.
Hope you can solve the issue.
Regards,
Marvin
Motorola Support.
Change battery on a motorola bluetooth H700
Turn off the unit before attempting a battery replacement. Without doing so, the power disruption that the headset will acquire can damage the internal workings.
  • Find the even **** on the bottom side of the unit, where the microphone boom is attached.
  • Place the edge of a flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up, however.
  • Find the small ring near the plug and the mini-USB port. Use the screwdriver to push under the ring where the battery is found. Push forward gently to pop the battery out.
  • 0helpful
    H700 charges fine, dies fast
    You need to Change its battery For Your Head Set . Only solution is battery Change.
    I changed phones and do not have the passkey for H700?
    Hi,the passkey for your h700 headset is "0000".this is the default passkey which will work for the pairing of your phone with the headset.
    Thanks and take care
    My motorola h700 won't turn purple to connect to my motorola i576
    Make sure the battery is good in your H700.Make sure your Bluetooth is enabled on your i576. To do this, go to Contacts>More>Bluetooth>Setup>Power> then select On. Back up one level and select Link To Devices. If everything is correct, they will find each other.
    Caller unable to hear me while using the H700 headset.
    Hi there , to solve this proble since you have the headset over 18 months you need to change the internal battary the life time for these handset battery up to 24 months try to replace it by take it to cellphone shop and im sure you be happy.
    5helpful
    Pass key
    h700 passcode is always 0000 4x the zeros unless it has been changed by a previous user then it is impossible to guess what it has been changed to. This was sourced directly from www.motorola.com
    How to pair a motorola H700 to a Samsung M300
    the code on the h700 is "0000" unless you have changed it, thats what the code typically is.
    10helpful
    79helpful
    5answers
    Need a passkey lost it
    The problem you are having with your H700 is not the passkey. "0000" is correct. The problem is the pairing process. I just paired mine after reading this with my blackberry curve.
    1. Close the H700.
    2. Hold the big button down until you see a lavender light.
    3. Open the H700 while still holding the button down.
    4. At this point it is ready to be paired. If the light changes color, the H700 has timed out waiting to be paired and you will have to do steps 1 thru 3 again.
    5. With the lavender light on the H700 go through the pairing procedure on the blackberry.
    H700 charges fine, dies in an instant
    Open it and see if it has a battery. Take the battery to RadioShack and have them get you the correct battery. Use contact cement glue to put it back together.
    Top Motorola Mobility Radio Communications Experts
    ADMIN Eric
    ADMIN Eric
    ADMIN Andrew
    ADMIN Andrew
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
