SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
SOURCE: Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
SOURCE: kyocera printer problem
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
SOURCE: changed black ink cartridge to LD brand. Now
Canon printers do not like non Canon inks. Maybe other printers have similar issues but it seems that Canon is particularly finnicky.
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
