When mac is off it displays colored screen. When mac is on little blue box, "out of range"
SOURCE: blue tint on computer display monitor
Try
1. Unplugging the video cord from the back of the computer (and screen if it comes off) and plugging it back in. Sometimes it can become loose and cause a screen to have a abnormal color contrast
2. Updating the drivers to your card
3. Trying a different monitor on the computer. Mind you, if you plug in a differant monitor and the color stays the same. Check the videocards pins on the back of the card. I dont know if you gave all the info on how it became like this, so maybe it got undone and plugged back in forcably and one of them got bent? I
Also if the pigment goes away. Plug the normal one back in and if its gone, great!, if its back. Try the OSD settings on that monitor. Still no luck. The monitor is junk.
Hope that helps
SOURCE: ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
SOURCE: my ViewSonic VG1930WM (Black) LCD Monitor wont turn on
You need to open it up and the first place to look will be the power supply, look for bad caps with bulging top, post back what you find so we can guide you further. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
SOURCE: ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
SOURCE: Monitor display stays for a few seconds only but has power always
I have the exact same issue with mine. Viewsonic VX2235WM turns on fine for about three seconds when asked to by my software attempts, but then shuts into sleep mode. I agree completely with BudMrtn. The issue is that your monitor has been through some stress and one if not multiple of the problems is due to part failure. In this case I would suggest a capacitor issue. First off make sure, for a fact, that you have the appropriate drivers. ( For Windows 7 I would suggest using the unsigned drivers from Viewsonic for this model. Now the reason that it is cutting off after a few seconds is because one of the capacitors is not sustaining a charge. It is showing as on for a sec because it is getting the appropriate power to operate but it is not receiving the appropriate level to maintain and is either shorting or free flowing the voltage inappropriately. Now the real question is... do you fix this issue. Well the monitor isn't the most expensive, but it is nice and would be worth the trouble. I would suggest you take a practice run on yours to learn a little something about repairing this level of issue. It is not a very hard fix but it is a very technical one. Understand that to you it is dead already, so what is the worst thing you can really do to it. Use absolute caution when handling these type of repairs. Make sure it is unplugged and use a muli-meter to find your short. I suggest you try and repair this because it is not as dangerous as a CRT. With a CRT you have to watch for residual charge... now you are looking for a busted capacitor which you must realize does retain a charge and electrocution can and more then likely will occur. Use a surge protector in case you screw up. Now if I am right the capacitor you are looking for is not holding a charge so residual charge is probably not going to be an issue... but you never know. Also always keep in mind that even though we have the exact same result, the issue may be varied to a degree of almost infinity. It smells like poo, it looks like poo, it even taste like poo, but it might be a ham sandwich, or a pigeon. My point to all of this is that you should not look at this as a downed monitor, instead you should view this as an opportunity to better get to know your electronics and how to repair them. Have fun and good luck.
