Washing machine is filled with water - door won't unlock so we can manually drain it and check for a clogged filter
If you unplug it from power, the door should unlock. if the lock is broken, then your take top off, take control panel off, take front off to get to lock
Look to the bottom of the washer some may have a drain plug next to the filter placement as to the LG TROMM washers....do have a bucket ready as it will come all out at once if ya take the filter cap off
SOURCE: Washing machine fills with water when not in use.
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
You have to replace your inlet water valves. Its simple.
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
SOURCE: Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
SOURCE: LG Front Loan washing machine
If your LG is similar to mine, there could be water in a hose that is located behind the small door on the bottom front of the washer. Open the door and drain the hose. Be sure to have a bowl or pan to let the water run into. Once the water is drained hopefully the washer door will open. When i brought my washer this was one of the selling features the sales person told me about.( The door and hose are accessible to the consumer to prevent them from having to call for a repair) Hopefully this will be your only problem. I bought an LG washer on June 28, 2008. It is now August 21st and my machine is still broken. It broke the FIRST time I ever used it (July 13th) and it still has not been repaired. (Per the repair person it is a water sensor problem which has been "ordered") I wish I had purchased another kenmore instead. I had my kenmore 16 years and never ONCE has a problem with it. I simply wanted to update my laundry room. WHAT A MISTAKE for me to purchase LG!!!!
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
