1.Check the input setting of your TV.Try to find the input setting of your TV go to menu and select the selected input you are using, its either rca input 1,2,3 or vga input.Try to read the label of your input if its input 1,2 or 3 then select the setting in input set-up.
2.Configuring the appropriate setting and still the problem did not solve.Try to substitute your DVD with another functional DVD.But before also replace your RCA cord to take away the probability of defective cord.After replacing another DVD and the problem is solve, your DVD setting must be check if its in pal or NTSC setting.Try to press N/P button on your remote.
3.If the following procedure does not work.Your unit needs to be check by an expert.This could be a service mode repair or internal components repair.
