Perhaps this will help:
Simple Fix for Janome E1 Error
Janome 8077 error code E1 fuse replacement
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiizvjqjMXPAhXG5oMKHTtaBhQQFggrMAI&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
SOURCE: E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
SOURCE: E1 error code.
The pressure foot was up instead of down when I tried to run the machine without sewing something.
SOURCE: Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
SOURCE: i can't sew on my machine
I had the same problem.There is a gold or silver washer on the back of the sewing machine that holds the part inside that you are connecting to. If the washer is gone or loose you will not get a connection when you insert the foot peddle. This peice inside is small and square with three delicate wires attached, You should be able to see it
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
