Question about Hoover Washing Machines
Hi i have a hoover dyn model with inverter motor and everything lights up but machine wont start a cycle i tried everything on the other machine and it is pcb is there any reset ?
Anonymous
SOURCE:
Tony Coultrip
  • 183 Answers
SOURCE: Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Posted on Dec 30, 2007
Anonymous
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
Anonymous
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
Anonymous
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Posted on Sep 17, 2008
orzechoski
  • 77 Answers
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Posted on May 08, 2009
I have a Hoover washing machine model( DYN 10146PG-14S)operates five seconds and then turns off everything? Is there anyone who can help me please
Sounds like electrical leakage to earth operating a circuit breaker, this can be caused by many things however perhaps most common is the Heater in the machine, disconnect both wires to this bottom of the drum then try machine to see if it powers up, if yes then get/fit new heater .
Sep 30, 2016 | Hoover Washing Machines
Hoover 800rl wont spin
sounds like an issue with the progrmmer if it does everything else, or there may be an issue which a sensor has caught that causes it to desist from spinning. Probably needs a repairman to diagnose..
Jun 03, 2015 | Hoover Washing Machines
Hoover washing machine manual
HOOVER DYN 10144 DP What does it mean ERROR E13 CODE
Mar 01, 2014 | Hoover Dishwashers
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover DYN 9144 DG - 80
washing machine won't start. display screen is flashing constantly, no error codes up. does any one know what the problem is??
Mar 23, 2013 | Hoover Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Dec 29, 2007 | Washing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
