SOURCE: The "dispose of used toner" error message will not clear.
Wash out the bottle with soap and water.
SOURCE: Hello!!! I want to ask about my toshiba E-Studio
It is a hardware problem.So pls you can checked it from service center.
SOURCE: want service manual of Toshiba photocopier model studio e-206
tradebit service manual link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: toshiba estudio 450 Used toner cartridge is empty
replace the ic of toner cart. problem will be solved
SOURCE: toshiba studio 352 dispose of used toner
The waste toner bottle is located behind the front cover, you should be able to open the cover and remove the clear plastic container. After emptying the container, you need to make sure that the portion of the container that comes in contact with the sensor on the machine side is clear of any toner, as the sensor sends a beam of light through it to determine if the container is full. After doing this, you may need to reset the machine.
-David.
