Devices can be different, but check your Settings. Find Display. Make sure "Auto rotate screen" is checked. Or sometimes it may be as simple as powering the device off then back on.
I'm assuming that the Nextbook uses an android OS for this answer. On the drop down menu that appears when you "pull down" the top right corner of the screen there should be a "rotation lock" button if it's on then turn it off, if it is off then there may be something wrong with the position sensor in the tablet.
You should be able to just turn the tablet on its side an the screen would auto rotate but if not go to settings an select screen settings/display an change the setting to auto rotate.
You are looking for an option called Rotation or Rotation Lock (varies by Android version and tablet). Once you find it, orient the tablet so it is in landscape mode, then turn off rotation. If you do not have an option on the bar at the top of the tablet (top pull-down you get by sliding down a finger from the top of the screen), then go to Settings, Display, and look for Rotation, Rotation Lock, or Screen Rotation.
You can't access pages like facebook from a Kindle, it will only load very simple text webpages, nothing as complicated as facebook.
To reset the device you need to just slide the power switch at the bottom, slide it to the right and hold it in that position for at least 15 seconds, you will see the device reset.
Please let me know if you have further questions, but the Kindle 3 is only meant for extremely simple text based webpages at this time, and special amazon formatted pages.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
