Kenmore Coldspot 106.56693501
SOURCE: Compressor starts, then stops
Hi, this problem will be with either the starter for the compressor or could actually be the compresser itself. Both of these can be replaced but it is not something any one should do unless they have done this before and know what they are doing.
SOURCE: Kenmore Fridge Beeping
Try unplugging the power cord and then after 60 seconds plug it back in.
SOURCE: Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
