Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
Posted on Jul 19, 2009
Sony wide screen projection tv model kp-57wv600 problem. Sound with no picture. Stanby red light blinks seven times? What parts do I need to repair the problem. Thanks ,Gary
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Aug 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
3779
Points
31
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Red stanby light is flashing with sound but no picture 1996 sony projection screen.I also here a clicking noise sometimes.
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
2answers
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
http://servicemanuals.vstore.ca/
2answers
Sony KP 57WV600
how many times does it blink?
Powers on then right back of light flashes 8 times
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
2helpful
3answers
Blue to Black screen on Sony KP-57WV600
i too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. ...so never change your tube it is not the prob!!!!!!!....go to www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
