Question about Frigidaire FGHF2366PF French Door Freestanding Refrigerator
FGHF2366PF5A refrigerator freezer drawer feels loose on right side and needs extra push to make sure it is closed. Have checked everywhere and there is nothing impeding the movement.
Rack and pinion to keep sides aligned won't stay aligned even if I correct it. Not sure what the issue is. Right side is very easy to pull open a bit and will easily move in and out where the left side seems to stay closed much better. Thanks.
6ya staff
SOURCE:
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Posted on Oct 14, 2007
Anonymous
SOURCE: Freezer Working, but Fridge side is not cold.
Excuse me, will not cool lower that 45.
Posted on Jan 27, 2008
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
Anonymous
SOURCE: freezer won't freeze
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
Posted on May 19, 2008
Joe Povoas
  • 111 Answers
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
Posted on Jun 19, 2009
How do I completely open a partially opened freezer drawer?
Hello Laura;
My name is Peter. I am a retired field service refrigeration technician.
Refrigerators with freezer drawers are nice up until the time that you need to call a service technician, and find out it cost about 40% more than a top or side by side refrigerator to repair.
If you leave your freezer drawer not completely closed, outside warm air enters your freezer and you get Ice build up on the rail system. It is difficult to see if the freezer drawer is completely closed because the fresh food section doors above block the view.
If you can pull the drawer out part of the way, use a hair dryer directly on the rail system on both sides in a effort to melt the restricting ice. Take your time. This may take several hours at which time you will push and pull on the drawer every 30 minutes until you break the rail system free from ice restriction.
After you have the door free, with a kitchen spatula and a hair dryer heat the gasket around the freezer door gasket pulling the gasket out to repair a possible crushed door gasket and not having a goo seal.
I have gone on service calls where the rail system ice was so built up, all I could do was to advise the customer to unplug the refrigerator for 36-24 hours to clear the ice from the rail system.
This is a common problem with drawer freezers. Next time get either a top mount refrigerator freezer or a side by side. Lower repair cost and more reliable.
Mar 06, 2016 | GE / Profile PFSF6PKXBB
The LG freezer door does not close fully on the right side but seals perfectly on the left side, ideas?
I would check and see if the drawer is just stuck, or has something in it, or just remove the drawer and see if it seals
Mar 02, 2015 | LG Refrigerators
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
Need gaskets for CSX20E Hotpoint side by side
Seals don't lose their magnetism. Check the door closes all the way round and adjust the hinges if it doesn't sit straight. Check there isn't a relief valve frozen up or blocked (it allows air to escape when the doors are closed). Check the drawers are fully pushed back in and not stopping the door closing properly
Sep 11, 2012 | Hotpoint Refrigerators
No cooling at all in fridge or freezer side. light still on in fridge and circulator fan blows in freezer
check you air damper
you should feel air near the top with the freezer door closed
mkae sure your air retrun behind the drawers is clear
Oct 10, 2009 | Whirlpool GS 6 SHEXNT Side by Side...
Freezer drawer closes on right but gaps on left side for Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator, frosting contents. No contents blocking. Can manually hold left side closed, but wont...
I had this problem with my Kenmore bottom freezer drawer also. I found that the problem was I had too much weight at the very front of the drawer. Try reorganizing and moving items, especially heavier items away from the very front. Worked for me.
Jul 10, 2009 | Kenmore 73503 Stainless Steel Bottom...
My freezer is frosting...there is snow all over
In my case with constant snow and frost build-up in my bottom drawer GE freezer, it was because the drawer never properly closed. As one user noted, "there is no adjustment." However, there are "catches" at the rear of the drawer glides and in my case one needed adjustment because it was preventing the drawer from remaining closed tightly. SEE PHOTOS. The photos show many items removed, but to make this repair, you only need a butter knife to pop out the black plastic catch mechanisms at the back end of the drawer glides, and only if you can see that the spring is not properly positioned. SEE PHOTOS
May 09, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer door wont stay closed.
If you can pull the freezer drawer out, check to see if there is anything on the floor of the freezer. You can also try reinstalling the drawer. When you take the drawer out make sure that the spring loaded door catches on the sides are facing towards you. That is if it has any.
Dec 02, 2008 | LG LRFC25750 Refrigerator French Door
Frigidaire FGHF2366PF French Door Freestanding Refrigerator Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
