Question about Hoover Washing Machines
My hoover dyn 9144 d3x is showing E04, I have emptied the drum of clothing and drained, I also emptied the pump, debris catcher and checked the condition of the rubber pipes feeding the pump Any ideas
Anonymous
SOURCE:
dazmaraz
Darren Moxam
  • 67 Answers
SOURCE: Hotpoint WD64, leaking water from soap drawer
your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
Posted on Aug 07, 2007
Anonymous
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
Anonymous
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
Anonymous
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
Anonymous
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
Hoover 550MB WASHING MACHINE wont empty
Please check the drain pump is working correctly. Empty my debris from the pump and any attached hoses.
Oct 17, 2015 | Hoover Washing Machines
Where is the coin catcher on a Kenmore Elite H3 washer
it is most likely the pump. you can remove the pump and debris trap easily, separate the pump from the debris trap by depressing a tab and turning the pump clockwise from the debris trap. the pump is a mag drive unit and is easily dis-assembled. ours had debris inside the pump, once taken apart there was some black colored fine sand inside that once cleaned out the pump returned to normal function. we bought a new pump but the old one still works since it was cleaned out, the rubber o ring had leaked letting the debris inside the impeller assembly. hope this helps out. it worked for ours
Dec 03, 2017 | Kenmore Washing Machines
Why whirlpool duet washer
There are a number of causes for a SUD error. The most common is using non-HE detergent or just too much detergent. Try taking the clothes out and running the washer empty. (Do not add detergent.) When the tub doesn't have any suds, retry with a small load and very small amount of HE detergent.
The next issue is clogged drain hose/pump filters. Take the drain hose off the back of the washer and clean any debris with Q-tips or similar until you see the filter screen. The pump filter is sometimes called a coin catcher. You'll need to carefully check that. Take a small bucket or bowl to catch the water when you disconnect the hose from the tub to the pump.
The final cause is a leak either at the detergent "box" or in the tub or a bad sensor claiming there is such a leak. If the unit is detecting suds outside of the tub, you will need to call for repair. Depending on the age of the washer, this may be covered under warranty.
I hope this helps.
Jun 04, 2013 | Washing Machines
Hoover DYN 9144 DG - 80
washing machine won't start. display screen is flashing constantly, no error codes up. does any one know what the problem is??
Mar 23, 2013 | Hoover Washing Machines
Lg washer will not spin with clothes in drum
If it spins empty i'd check drive belt (if it has one) or motor. If it just won't spin i'd check the drain hose between tub and drain pump for debris. If no debris i'd check door switch.
Jan 13, 2013 | LG WM Washing Machines
When we attached the machine and started it we realised the water is draining out from the drum. this happend with our previous one too . cant understand
That is the problem of washing machine!
Check ur DRAiN valve and solenoid!
Either ur DRAiN valve stuck OPEN because of those DEBRiS from ur clothes or coins from ur pants!
Nov 07, 2010 | Hoover Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Pool of water in the drum if I let the clothes sit.
this is a very comon problem, not really witht the machine though. well i guess it is now.
you have debris / change / other stuff.... lodged into the pump
remove the lower access panel, disconnect power, there is a screw out portion on the pump, nail catcher. remove it and catch all water that comes out with a towl. unscrew it slowly to allow the water to slowly come out, or it will make a mess.
the clamp that secures the drain boot to the tub, loosten it and remove. use a large towl to catch the watter that comes out.
remove the spring clamp from the drain hose and remove the drain hose. again use a large towl to catch water. disconnect pump power supply and remove the screws that secure it to the washer, remove pump.
clear all debris from the pump and check to see if anything has damaged any impellars in the pump. do this with your finger.
clean out the rubber boot as well.
reasemble in reverse order.
before the access panel is put back, start the machine and visually check for leaks. if it leaks reset the rubber and clamp where it is leaking.
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code e04 on hoover washing machine
Jul 27, 2008 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
