Question about Sanyo Televison & Video
I have a Sanyo tv and a sansui remote. How to pair please
  • 2,559 Answers
Unless the Sanusi remote is a universal remote it will not work a Sanyo tv
Posted on Oct 17, 2016
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: DS27930 27" TV: I have a Sanyo DS27930 tv and the remote hasn't ha...
check the remote control for any rust on the contact terminals of the dry cells.If present sratch it off and place back the cells and see if it operates.if it does not work you can easily identify the between the tv or the remote what is mulfanctioning by testing the remote for ir radiation,simply by directing the remote to a camera sensor of your mobile phone,if ir light is seen as you press the buttons then the remote is good and if not then the remote is faulty and might need technical expertise to repair.however if you see the ir light ,the problem lies with our set
Posted on May 20, 2010
Can you give me the codes for a sanyo tv for a universal remote
try this link...4 digit GE codes for TV sets including LCD, Plasma, and Panel TVs Brand Code SANSUI SANTECA SANYO SCOTCH 224 more rows
4 digit codes for TV sets including LCD, Plasma, and Panel TVs - GE ...
www.eliztech.com/remotes/ge-4digit-tv-codes.php codes for sanyo tv for universal remote Google Search
Dec 09, 2016 | Sanyo Televison & Video
What is the code of a pavy universal remote for a sansui TV
SAMSUX 009 SANSUI 135 136 SANYO 004 013 049 108 110 180 209
Oct 24, 2015 | Universal Televison & Video
Code for sansui TV on universal remote control
SAMTRON 0351
SANSUI 0371 1631
SANTECA 0171
SANYO 0001 0801 1051
1161 1261 1531
1581 1911 2871
Sep 19, 2015 | Universal Remote Control Televison & Video
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | Sansui Televison & Video
My remote for my SAN3210 TV has been broken and i cannot get a universal remote working with the sansui 0711 code. Am I able to get a replacement or get the correct code
Using a universal remote for your television, you have to get the correct code to pair up the remote with your television before the remote can start working with your television.
Most of the time you only get wrong codes.
I strongly advice you contact sansui customer care and explain the situation to them, they will further tell you either how you can get your universal remote to work or get you a remote that will work for it.
You can get a sansui HDLCD3210 remote froman electronic shop, i bet that will work for it.
Take care
Jun 26, 2010 | Sansui HDLCD3210 32 in. LCD TV
I need the codes to program the remote to a sansui television
Sansui tv share same codes with: Magnabox, phillips, Sanyo, Sears, Sylvania, Teac, Toshiba, sampo, Symphonic, Zenith.
Try codes from these manufactures using your remote code table.
Dec 04, 2009 | GE JASRM24912 Remote Control
Unable to pair a Philips Universal remote with Sansui TV
Hi
1032, 1051, 1052, 1054, 1061, 1075, 1079, 1091, 1140, 1157, 1173, 1203, 1209, 1232, 1237, 1258, 1287, 1337, 1339, 1340, 1375.
Regards
Phillip
Aug 15, 2009 | RCA RCR311B Remote Control
I have a connect-it remote control and i need a code for a sanyo tv can u help plz
hello not sure what your remote model number is but i have instructions for the ER-440 and the codes given for the sanyo tv are as follows...
0141, ...0601, ...0981...1111,...1691,...2091,...0151,...0801,...1021,...1291,...1741,...2251
,...2551,...04011,...0821,...1101,...1351,2051
Hope this helps
happy new year.
Dec 22, 2008 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
