Have reset camera to factory default.
Resetting the system
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
1 Switch the receiver into standby.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
The display shows RESET? OK.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
