How to Find my IP Address (Windows 7/8, Windows XP)?
  • 1,061 Answers
If you go to your windows search box and type in CMD you will be defaulted to dos and then you can type in : IPRelease command and then type in : IPRenew and your new IP address should show in dos. Hope this helps.
Posted on Oct 19, 2016
6ya staff
SOURCE:
HOW TO PUT MY IP.ADDRESS IN
Open the Start Menu, right-click on Network, and select Properties. The Network and Sharing Center opens...click on Manage network connections. Right-click on the network adapter you want to assign an IP address and click Properties. Highlight Internet Protocol Version 4 (TCP/IPv4) then click the Properties button.10 Nov 2013
How to Assign a Static IP Address in Windows 7, 8, 10, XP, or Vista
www.howtogeek.com/howto/.../how-to-assign-a-static-ip-address-in-xp-vista-or-window... HOW TO PUT MY IP ADDRESS IN Google Search
Dec 09, 2016 | Computers & Internet
Tip
How to determine what your computers IP address is
How to determine what your computers local IP address is
Applies to Windows XP, Windows Vista and Windows 7
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Next at the command prompt type "ipconfig" and press enter
At this point all your active connections will list on the screen. Note you may need to scroll back up the window to get to the connection info you need. Also keep in mine if you are connected to your wired or wireless connection because both might have an IP address assigned but you can only be actively connected to one at a time not both.
4. Look under the Local Area Connection if connected to your network via a wired connection or Wireless Network Connection if connecting via a wreless connection.
Once under the right connection you will want to look for the line that shows "IP Address" this will have what the computers current IP Address is. Note if you have Windows Vista or Windows 7 it will be listed as "IPv4 Address". Also while you are here take note to what the "Default Gateway" is because if you are trying to network computers together you want to make sure they are connecting to the right network.
Here is an example of what IPCONFIG looks like on a computer running Windows 7
Other Helpful Links
How to allow ping request through Norton Internet Security 2010 Smart Firewall
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
How to determine your computer's MAC address
on May 24, 2010 | Computers & Internet
How can i get an ip address
Firstly, what operating system are you using?
applicable for windows xp or windows 7. press Windows Key + R
select the appropriate network connection (e.g. Local Area Connection). Right click the Local Area Connection choose Properties. For windows xp, doble click Internet Protocol. For Windows 7, double click Internet protocol IPv4. choose Obtain an IP address automatically. press OK. right click again the Local area connection then choose Status. there tou can see that your computer is negotiating for an IP address from the dhcp server. if still cannot obtain an ip address, press Windows key +Run then type "services.msc". scroll down and find DHCP client. ensure that this service is running.
Please also try to check if the network you are connected does have a DHCP server.
Jul 01, 2013 | HP Compaq nc6220 Notebook
How to set an ip address
To set an IP address in your PC Laptops (Windows 7, xp and vista) visit the site Howtogeek.com ,here they have given detailed procedure to sen an IP address of your own. After setting an IP address you can check it in two ways.
1)Go to Start-> Run-> Cmd Press Enter.. Type ipconfig or ipconfig/all command line to know your IP address.
2)Visit the site Ip-Details.com to get your IP address.
Apr 10, 2013 | Computers & Internet
Unable to connect windows xp and windows 7 using crossover cable.
Your laptop ip address setting is correct now there is reason not able to ping windows xp and windows 7 have firewall you need to enable file sharing form windows firewall. Go to control penal > windows firewall > advanced settings > inbound rules and enable file and printer sharing.
Jun 15, 2012 | HEWLETT-PACKARD HP 630/P6200 Notebook
Trying to open port 3389 in my firewall. Set for UDP and TCP but the tester program still says that they are closed. I have disabled windows firewall. Still no luck.
Make sure you are doing this for the right ip address. The ip address should be your local computer's ip address and will probably look like 192.168.1.x . To get to this go into your network control panel and click on your connection and view the details to get this information. Remember that every time your router resets this ip could change. I would suggest setting a static ip in either the router or on your computer in question. To set up a static IP for windows xp: http://portforward.com/networking/static-xp.htm. For windows Vista:http://portforward.com/networking/static-vista.htm. For windows 7: http://portforward.com/networking/static-win7.htm.
May 13, 2011 | Belkin F5D8236-4 Router
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
How search for ip address
hi there,
Flip the router over,you would see the IP address.
or
Click on start and select run( if you are using Windows XP) and type in ipconfig and hit enter.
Default gateway is your routers ip address.
Type in ipcofig in Quick search and hit enter, if you are using windows vista or windows 7.
Nov 27, 2010 | Computers & Internet
I have an aptiva desktop and i need an ip address in order for my internet to work
But do you have any internet connection??if yes and if its DSL than ur dsl router will automatically provide ip to ur pc???
Sep 08, 2010 | IBM Aptiva E 572 (2174572) PC Desktop
Looking for default IP adress for my cnet car 854
1. Connect your router to your computer via ethernet cable
2. Now we will check the IP Address
Windows XP
1. Click "Start"
2. Click "Run"
3. Type "cmd" without quotes
4. On the black screen type "ipconfig" without quotes
5. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
Windows Vista
1. Click "Pearl button" (Start button in XP)
2. Click "Start Search"
5. Right click the black icon up at the top of the window
6. Click on "Run as administrator"
7. Click on "Continue"
8. On the black screen type "ipconfig" without quotes
9. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
I hope this helps you.
Jan 06, 2010 | Cnet Wireless-G CAR-854 Router (CAR854)
Computers & Internet Logo
78 people viewed this question
Ekse
Marvin
Marvin
