I just installed a onga pump to my spa (2nd hand) and the heater was working fine. Now everytime the heat light turns on it trips the power. If i turn heat right down everything works fine. Cheers
with power disconnected take off cover take off heater leads (remember where they go take a picture ore write a note if you turn it on and doesnt blow fuse its a bad heater element
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check. If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly. If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in. If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
This could be caused by a couple things. In order for your spa to heat your pump must be working, your heater and heater sensors must be good. If your heater is bad usually the breaker will trip. If that's not happening read below... Does water shoot out of the jets when you press the jets 1 button? If not then you have a bad pump or the pump is air locked. The heater can't turn on if the pump does not push water through the heater. You'll know if this is happening because you'll get an error code on your control pad. So your jets are working but no heat. This is the most common problem. Your spa has a sensor that tells the spa if it's ok to turn the heater on. That sensor is prone to failure so everything can be fine but the heater will not turn on. Get the model number off your spa pack and click the link below. Call and tell them you need a pressure switch and give them the model number. Install the new switch and you're back in action.
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Have your installer check your wire connections first. These use a lot of power in turn the connections get hot leading to oxzidation leading to more heat...A vicous cycle. Other than that 40a sounds a little light depending on elect run and load on heater.
