SOURCE: no screen and the power and opc light flash on lc-46e77un tv
Final Up date, The TV is fixed, with my problem it was found that the units Mainboard was defective. If you go to replace your Mainboard MAKE SURE THAT YOU PURCHASE THE CORRECT BOARD AND VERSION NUMBER OR IT WILL NOT WORK...... for example KE833 XE833WJ and the most important part, look for the version on the White lable markings, mine was FM11S it will be some FM number that will be used on your Set. Hope this helps you solve your problem.
