There are several possible reasons for sewing machine needle breakage. Make sure you are using the correct needle for your machine and it is inserted properly. Is the top thread threaded incorrectly. Try removing all the thread and rethreading from the beginning. It may be looped around a guide or hanging up so when the thread has stretched to its limit, it pulls the needle off course and causes it to collide with the needle plate or presser foot. Make sure the upper tension is working and not too tight. It could very well have a timing issue so the needle is not in time with the bobbin.
sewing machine need break Google Search
First make sure you are putting in needle correctly, it has a flat side.
Insert a new needle into your sewing machine with the flat side away from you. Push the needle into the clamp until it touches the pin (a) and stops. Firmly tighten needle clamp screw with the screw driver.
if you find all the thread bunched up then look at your thread not being routed through all the the locations. Go slow and retread from beginning.
