SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: I have a frigidaire gallery washing machine that won't spin
defective motor control board..onthejob
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
