I have a CenterG CG3 stair stepper and it just stopped working. When I plug it in the receptacle nothing happends (does not turn on). Any thoughts? Thanks Leon
This could mean that the machine is either not plugged in or has a malfunctioning power cord. First, check to make sure the machine is plugged in and that the outlet is working. If it is plugged in and still not working, then you may need to replace the power cord.
This sounds like you have a stuck key on your keypad. A new overlay keypad should correct your issue. The following link will show the some options for replacement.
The following link will take you to the items we have available for your Star Trac SC4100. You can use the tabs on this page to see an owners manual, service manual and a diagram.
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly?
Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
Usually, when one drive sprocket fails, the other isn't too far behind
The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
