SOURCE: polaroid flm 323b no power
FLM-323B same problem, black screen. Checked out the power board and there is no 24v on it. Took the board out, let it cool off, put it back in. Got my TV back for a while, checked for 24v and it is there. Worked for a few weeks, now it's out again. Known issue with Polaroid, and if it's out of warranty, might as well throw it away because they WILL NOT help you. Personally this was my first and LAST POLAROID TV ever, TOTAL JUNK.
SOURCE: FLM-323B Power Problem
If this the same as mine 32" 0409do2244LF power supply. I just changed C33 and C34 and got the 24vdc on (I still plan on changing all of them) Note that all capacitors looked fine.
SOURCE: Polaroid FLM 323B - No picture
Problem Solved, I replaced the third capacitor (the same mf and V as the other two) and now it works great. I'd like to say "Thanks" to all of the folks who had a helping hand in this one!
SOURCE: Polaroid FLM-323B Will not turn on
Polaroid FLM-323b No power,No led light, checked the fused and the fuse is good?
Can't find any bad Caps? Well I spent some time, well alot of time trying to figure out what's wrong and finally did.
The problem is a diode on the power board location Z9 Part # ( P6KE350A )On some boards it's the diode and the capacitor right next to it part # ( R 331K 1KV )
If this works Please donate Paypal [email protected] anything helps Ive spent well over a weeks time and count less hours trying to figure out what was wrong.I have included some pics to try and help.
Thanks Z28r2fast4u
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
