Tablets & eReaders Logo
b
bepandnick Posted on Nov 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No how to unluck my ipad - iPad Apple Tablets & eReaders
Michael Lei
Level 3:
Master:
  • Apple Master 498 Answers
  • Posted on Jul 18, 2019
Michael Lei
Apple Master
Level 3:
Master:
Answers
498
Questions
0
Helped
121977
Points
1736
There are a number of ways to unlock iPad. You can resort to iTunes or iCloud "Find my iPhone" feature. Just follow below steps to do that.
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
For more methods, check: How to Unlock iPad?
Wanted to transfer from an iPad mini two to an iPad 4
It's easy. There takes transferring music as an instance. Just follow the below steps.
Step 1 Start Leawo iTransfer
Connect old iPad to computer via USB cable. Start Leawo iTransfer on your computer. The software will automatically recognize your device and shows iPad library in the left sidebar.
Step 2 Select music to transfer
Click the name of iPhone and go to "LIBRARY > Music" in the left sidebar and select multiple songs in the right interface by holding "Ctrl". Right click them to choose "Transfer to > My Computer".
Step 3 Transfer music from iPad to computer
In the pop-up window, chose "Save to folder" and click on "Change" to select an output directory on your computer. After that, choose "Transfer Now" to transfer music from iPad to your computer.
Step 4 Transfer music from old iPad to new iPad
Disconnect iPad but connect new iPad to your computer. Go to "iPad > LIBRARY > Music" in the left sidebar. Choose "File > Add > Add File or Add Folder" in the top middle to upload music you just transferred from old iPad to your new iPad.
For more details, check: How to Transfer Music from iPad to iPad
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
4answers
How do I transfer pictures from iPad 1 to iPad 2 .
Can you install Dropbox app on both tablets to transfer pictures? Or feel free to try this iPad file transfer program on your computer. Transfer Files among iOS Devices iTunes and PCs with Ease
2answers
Disabled ipad 3
What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
2answers
How do I know if my iPad is an IPad 2 or 3
check the model nr. on the back side:
Apple Device Model Number
1iPad Wi-Fi (Original/1st Gen)A12191
iPad Wi-Fi/3G/GPS (Original/1st Gen)A13371
iPad 2 (Wi-Fi Only)A13951
iPad 2 (Wi-Fi/GSM/GPS)A13961
iPad 2 (Wi-Fi/CDMA/GPS)A13971
iPad 2 (Wi-Fi Only, iPad2,4)A13951
iPad 3rd Gen (Wi-Fi Only)A14161
iPad 3rd Gen (Wi-Fi/Cellular AT&T/GPS)A14301
iPad 3rd Gen (Wi-Fi/Cellular Verizon/GPS)A14031
iPad 4th Gen (Wi-Fi Only)A14581
iPad 4th Gen (Wi-Fi/AT&T/GPS)A14591i
iPad 4th Gen (Wi-Fi/Verizon & Sprint/GPS)A14601
iPad Air (Wi-Fi Only)A14741
iPad Air (Wi-Fi/Cellular)A14751
1helpful
4answers
The PC on which I had itunes that synced with my ipad is no longer available. I want to transfer the music on my ipad to a new PC (with itunes). How do I do this transfer?
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
9helpful
16answers
How can i watch wmv clips on my IPAD ?
iPad can't play WMV video directly, you can install a VLC player on your iPad, which can player most of the videos. Or you can convert WMV to iPad supported format(MP4 ,MOV), here i recommend a free converter for you, Aneesoft free wmv video converter which can help you solve this issue.
Thanks for your interest in fixya please do be considerate to leave positive feedback and ratings for me if you feel my answer have helped you. Thank you.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
