Samsung Galaxy gc200 21x zoom camera/tablet. black spot on screen 3/8 inch in diameter not round. Cleaning lens and blowing air didnt remove it. Is it dust or pixels going bad ????
SOURCE: no image output on screen or viewfinder
If you can see images in play mode, previously taken pics, then check to see if iris is opening and closing, could be seized vanes on iris motor. Tap on the lens(just not on the glass) repeatedly, this might help jog the vanes open. remove batteries, reinsert them after an hour, or a cup of coffee. If it persists press the reset button . all your settings will be cleared. Check to see if there's a second internal battery used for function memory, if there is, remove that one too for a while. Sounds a lot like the global CCD sensor problems that most manucturers had last year, but I don't remember anything regarding panasonic in that context. Use your warranty if valid Good luck
SOURCE: Spot on digital camera lens
No. You can't take the lense apart for the cleaning by yourself. Any expert pro camera repairer will do the job
SOURCE: black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
SOURCE: Black spot on picture
My Nikon was having the same problem with the stationary black spot. I used a can of Dust Off ( the original compressed gas duster). I just removed the lens and held the camera upside down (lens facing the floor) and blew my compressed air inside and my black spot disappeared. Just a thought you might like to know !! Good luck.
SOURCE: How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
